Gringosteve 213 Report post Posted July 3, 2015 Hi, I discovered the alarm control panel in the glovebox today, and the post on here describing how to turn on anti-hijack doors. This inspired me to find more codes. It turns out the alarm is a Sigma S32, shared with the 2014 impreza. Codes to play with (AT YOUR OWN RISK) are below. I haven't tried all of these (yet!):PLEASE MAKE SURE YOU KNOW YOUR PIN BEFORE YOU TRY THE ANTI KEY THEFT CODE - YOU NEED THE PIN TO START THE CAR! (Hope that was clear! my mate's scooby was dead for 2 days until he got hold of the previous owner and his PIN!)Sources:http://www.perth-wrx.com/vb/mechanicals/58018-2014-wrx-technical-issues-3.htmlhttp://www.scoobynet.com/security-16/953357-sigma-s32-codes.html The S32 Installation guide (i bought a copy!) ----------------------------------------------------------------------------------------------------------------------- Standard user controls ----------------------------------------------------------------------------------------------------------------------- Ignition Must be ON, not on Accessory power 0 - Last Trigger Isolation --> Allows the alarm to ignore the last sensor that caused the alarm to sound. Effectively used to disable faulty sensor but still turn the alarm on 1 - Turns off the alarm arming tone for the next time used (if tones are set) 2 - Turns off the ultrasonic sensors for next time used 3 - Turns off the sensor prewarning feature for next time used 4 - Turns off the single and dual trigger sensors for next time used 5 - Turns off the ultrasonic, single and dual trigger sensors for next time used 6 - combination of 4 and 5 7 - switches safety lock on/off (so car locks as you turn on ignition) 8 - display battery voltage 9 - nothing * - toggles volume of prewarn beep To make the passenger door unlock at the same time as the driver door: Ensure ignition is off, driver door left open. Hold the lock and unlock buttons together for about 5 seconds (it will issue a beep) ----------------------------------------------------------------------------------------------------------------------- Super secret squirrel programming codes ----------------------------------------------------------------------------------------------------------------------- To use : Ignition must be offReset to default settings: *17856*880#Auto arm with door locking 60 seconds after the last door has been closed, Note make sure keys arn't in the vehicle: *17856 wait for the beep *004*1# turns it on. everytime a door is opened it will beep twice to inform you that its active Auto arm without door locking 60 seconds after the last door has been closed: *17856 wait for the beep *003*1# turns it on. everytime a door is opened it will beep twice to inform you that its active door unlock/locking beeps: *17856 wait for the beep *000*1# turns the beep on when locking and unlocking although admittedly not very loud *17856 *002 * 0 or * 1 then # Turns on safety locking through the programming code (similar to pressing 7 in the user options) but with more options on lock timings and pulse *17856 *005 * 0 or * 1 then # Auto-Rearm & Relock (if the alarm is turned off but no doors are opened etc) *17856 *007 * 0 or * 1 then # Accessory Wire 4 Function Can be used for boot release upon button hold or can be configured to allow Remote Engine Start/Stop devices (such as turbo timers i guess). If you need more info please ask *17856 *008 * 0 or * 1 then # Accessory Wire 3 (Total Closure) Operation - on Arm *0 = “Timed”. A passive, timed negative output is provided on Acc. Wire 3, every time the system is armed, to operate Total Closure (Total Closure Time *121 must be adjusted from 0 to select the output period if required). When held on arming, TX button 1 still operates Panic. *1 = “Hold Down”. A negative output is provided on Acc. Wire 3 only whilst TX button 1 remains held on arming after 3 seconds, up to a maximum of 26seconds (Total Close Time *121 will not affect the output time) When *1 selected, panic can only be operated from optional 2 button TX NB: Only S30 & 34 models. * 0 (“Timed” & Panic)*17856 *009 * 0 or * 1 then # Extend Standard CDL Lock Pulse - On/Off (only when TX button 1 held) Can be used with the above or as an alternative total closure option, where the vehicle already has a total closure circuit that can be operated from the standard CDL lock connections. When switched on, the Std CDL Lock pulse is extended (second pulse in the case of double pulse settings) as long as the TX button remains pressed, up to a maximum of 26seconds. When *1 selected, panic can only be operated from optional 2 button TX * 0 (off)*17856 *010 * 0 or * 1 then # Arm/Disarm Indicator Flash - On/Off For both radio key and direct switched systems * 1 (on)*17856 *011 * 0 or * 1 then # Accessory Wire 8 Function - *0 = Internal Panic Circuit. Configures system to activate Panic Mode whilst an earth input is detected on this wire. *1 = Closed Loop Protection. Configures system to trigger when the circuit becomes open when armed. NB: Only S1, 4, 30, 32 & 34 models * 0 (Internal Panic)*17856 *012 * 0 or * 1 then # Positive Door Switch Input or Internal Panic Circuit *0 = Internal Panic Circuit. Configures system to activate Panic Mode whilst a 12v input is detected on this wire. *1 = Positive Door Switch. Configures system to trigger when the circuit becomes 12v when armed. NB: Only S12, 30, 32 & 34 models * 1( “+” Switch)*17856 *013 * 0 or * 1 then # Key Theft Protection - On/Off NB: Only S4, 30, 32 & 34 models * 0 (off)*17856 *014 * 0 or * 1 then # Accessory Wire 6 (Headlamp Illumination) Operation - *0 = Arm Only. Configures the timed output to occur only when the system is “actively” Armed (illumination does not occur when Auto-Arming or Auto- Rearming). *1 = Arm & Disarm. Configures the timed output to occur when the system is both “actively” Armed & Disarmed (illumination does not occur when Auto-Arming or Auto-Rearming). NB: Only S30, 32 & 34 models * 0 (Arm Only)*17856 *015 * 0 or * 1 then # Accessory Wire 1 Function - *0 = Alarm Armed Output. Negative output provided whilst the security system remains armed. *1 = Total Closure Output. Negative output on arming, this can be “timed” or on “hold down” adjustable using *008 and *121. Wire 1 then behaves and can be adjusted as Wire 3 would be if fitted. NB: Only S4 models *0 (Armed Output)*17856 *016 * 0 or * 1 then # Accessory Wire 2 Function - *0 = Aux Siren/Pager Output. Negative output provided whilst the security system is triggering. *1 = Total Open/Boot Release Output. Negative output on disarming, this can be “timed” or on “hold down” adjustable using *006 and *122. . Wire 2 then behaves and can be adjusted as Wire 4 would be if fitted. NB: Only S4 models ----------------------------------------------------------------------------------------------------------------------- Other stuff I have if needed ----------------------------------------------------------------------------------------------------------------------- Sensitivity Adjustment Timings for locks and lock pulses (unlikely you will need this!) Diagnostic codes to hunt for reasons why your alarm is having issues Adding keys to the system Installation and wiring info 3 Test Drives Unlimited, ThatGuyThere and TommyC reacted to this Share this post Link to post Share on other sites
Gringosteve 213 Report post Posted July 3, 2015 I just tried the door locking beep code and it works. Need to be in the car, with start button pressed only once (aux not on) _____________________________________ www.im-tuned.uk Share this post Link to post Share on other sites
S18 RSG 429 Report post Posted July 3, 2015 I would certainly be interested to know if the total closure works. This is something I was quite surprised didn't come enabled as standard, though I had a feeling it would be a setting somewhere. If nobody has chance to try before I get home, I'll try it myself. Just to confirm however, I don't need to know my pin to enable this feature do I? If I understand this right, you only need the pin if you enable the anti key theft code (*17856 *013). Share this post Link to post Share on other sites
Gringosteve 213 Report post Posted July 3, 2015 That is correct, pin isn't needed. You just need fast fingers. I'm not sure i understand what the total closure option does? _____________________________________ www.im-tuned.uk Share this post Link to post Share on other sites
Gringosteve 213 Report post Posted July 3, 2015 And if you want to change your PIN (NOT TESTED!): Provided that you can disarm the system with a working Radio Key or the current PIN, then you can re-set the 4-digit PIN to one of your own choosing yourself, using the keypad, at any time. If you do not have the current PIN, then option A is your best solution. However if you do not have a working Radio Key, then you will have to use option B and obtain the systems PIN code from Subaru (UK). Your dealer can obtain this for you if you can provide proof of ownership and the alarm systems 16-digit serial number. A. Using a working Radio Key: - Arm and then Disarm the system using a working Radio Key. - Within 30 seconds of disarming, type into the keypad- *17856*92*wxyz*wxyz# (where wxyz is your new PIN code) - Arm the system with the Radio Key - You should now be able to disarm the system using the new PIN code B. Using the current PIN Code (if a working Radio Key is not available): - Arm and then Disarm the system using the current PIN - Within 30 seconds of disarming, type into the keypad- **abcd*92*wxyz*wxyz# (where abcd is your current PIN code and wxyz your new PIN code) - You should now be able to arm and disarm the system using the new PIN code When using the keypad always observe the following points: - The PIN number should not be entered too quickly or too slowly - when a digit has been pressed the small LED built into the keypad will illuminate briefly as confirmation and only then should the next digit be entered. - If an incorrect digit is pressed or the delay between entering digits exceeds10 seconds, then the LED above the keypad will flash rapidly and the PIN attempt should be abborted and started again after 30 seconds. - Due to the small size of the keypad some users may find a rubber tipped pencil easier to use. DO NOT use the sharp tip of a ball point pen etc, or press excessively hard on the keypad as this will only damage the membrane and cause a digit to remain pressed, causing a continual incorrect PIN. - The keypad allows only THREE PIN attempts and then will lock up if an incorrect number is entered a third time. This is a security feature to prevent random PIN attempts disarming the system. Share this post Link to post Share on other sites
Gringosteve 213 Report post Posted July 3, 2015 I can confirm the auto lock setting works also. They should have supplied these codes in the manual _____________________________________ www.im-tuned.uk Share this post Link to post Share on other sites
Omer86 40 Report post Posted July 4, 2015 Is there anything on "follow me home" lights? Share this post Link to post Share on other sites
Gringosteve 213 Report post Posted July 4, 2015 There is a code for it, but suggests it is turned on by default. It could be that the alarm is not connected to the headlights wiring. Worth trying to see what it does: *17856 *014 * 0 or * 1 then # Accessory Wire 6 (Headlamp Illumination) Operation - *0 = Arm Only. Configures the timed output to occur only when the system is “actively” Armed (illumination does not occur when Auto-Arming or Auto- Rearming). *1 = Arm & Disarm. Configures the timed output to occur when the system is both “actively” Armed & Disarmed (illumination does not occur when Auto-Arming or Auto-Rearming). NB: Only S30, 32 & 34 models * 0 (Arm Only) _____________________________________ www.im-tuned.uk Share this post Link to post Share on other sites
Gringosteve 213 Report post Posted July 4, 2015 Codes proven to work so far: Beep on door lock/unlock -no problems Auto lock and arm alarm after 60 seconds -works but make sure you turn your ignition off when you get out of the car! If your car autolocks with the ignition on it disables keyless entry and key fob entry. The only way in with your proper key! I have now turned this off as it caught me off guard when I was sat in the car with the ignition off Unlock both doors - works great Codes that don't seem to work: Total closure - I'm assuming the windows are not wired into the alarm module Share this post Link to post Share on other sites
Solwood 10 Report post Posted July 4, 2015 Is there an option to fold the mirrors when locking the car please Share this post Link to post Share on other sites
Omer86 40 Report post Posted July 4, 2015 Tried it and everytime i got to * then 1 the little led started flashing very fast? Was i double pressing perhaps? Will try another code later to see if its me or the code Share this post Link to post Share on other sites
Omer86 40 Report post Posted July 4, 2015 Is there an option to fold the mirrors when locking the car please No there isnt you need to buy a separate module and install it by removing door cards etc. Share this post Link to post Share on other sites
Gringosteve 213 Report post Posted July 4, 2015 Tried it and everytime i got to * then 1 the little led started flashing very fast? Was i double pressing perhaps? Will try another code later to see if its me or the code My post was wrong. Ignition needs to be off completely, corrected the post. _____________________________________ www.im-tuned.uk Share this post Link to post Share on other sites
Omer86 40 Report post Posted July 5, 2015 Ah i will try again n let you know if it works Share this post Link to post Share on other sites
Special K 442 Report post Posted July 5, 2015 I think Idrew has programmed autofold mirrors on his Malta-based car... might be worth asking him. Spec K Share this post Link to post Share on other sites
Solwood 10 Report post Posted July 8, 2015 I may have missed this but how do I stop the system arming if I only open the boot Every time it beeps and then sets the alarm of 1 Solwood reacted to this Share this post Link to post Share on other sites
Omer86 40 Report post Posted July 8, 2015 Which code did u try? Share this post Link to post Share on other sites
Lauren 2259 Report post Posted July 9, 2015 As long as you don't lock the car with the boot open it won't arm. Opening the boot in isolation does not set the alarm off. The common mistake is to open the boot from inside the car, then lock it, which obviously arms the alarm and will lead to the beeping. 1 Gringosteve reacted to this Share this post Link to post Share on other sites
BigJames 15 Report post Posted July 9, 2015 To make the passenger door unlock at the same time as the driver door: Ensure ignition is off, driver door left open. Hold the lock and unlock buttons together for about 5 seconds (it will issue a beep) Thanks, that was bugging me every time I've had a passenger so far Share this post Link to post Share on other sites
Gringosteve 213 Report post Posted July 9, 2015 No worries I nicked it from some other forum/post. Payment by cheques/PayPal/beer welcome _____________________________________ www.im-tuned.uk 1 BigJames reacted to this Share this post Link to post Share on other sites
iddrew 86 Report post Posted July 9, 2015 Wow! awesome info! I'm sure it will be very useful! great work! Yes Special K is right, i did program the auto-fold mirrors when locking and unlocking the car. i could have taken the easy way out by buying a module but since a friend of mine prints custom PCBs i decided to build my own circuitry with an ATmega micro-processor and other bits and bobs and do it myself. Thanks for the info @Gringosteve! 2 Gringosteve and Omer86 reacted to this Share this post Link to post Share on other sites
Gringosteve 213 Report post Posted July 9, 2015 You could make a killing on selling those modules, especially now we know which accessory wire to hook up to _____________________________________ www.im-tuned.uk 1 Omer86 reacted to this Share this post Link to post Share on other sites
Gringosteve 213 Report post Posted July 9, 2015 I have bought the full installation and programming manual now so may have some more codes to add _____________________________________ www.im-tuned.uk 2 BigJames and Omer86 reacted to this Share this post Link to post Share on other sites
Gringosteve 213 Report post Posted July 9, 2015 UPDATED! Share this post Link to post Share on other sites
Solwood 10 Report post Posted July 9, 2015 Lauren our cat was doing exactly what you say it shouldn't Came home, got out of the car, did not lock it, opened boot and alarm sounded after A minute or so Hit unlock on the remote and it happened again, in fact it happened 4 times. Very frustrating. In answer to the other question i have not tried any codes yet because I could not see any for this. At least from my reading of the descriptions 1 Solwood reacted to this Share this post Link to post Share on other sites
