Adam9 37 Report post Posted January 27, 2017 As I've been unable to find this anywhere else I've created a printable template for cutting your own front door speaker baffles. The preferable way to do this is to print the PDF with no scaling, it should print to the correct dimensions on A4 but check the measurement guides against a ruler before you start work to make sure they are correct. The guides should be accurate to within less than 1mm, if they are out then the template has been scaled by your printer or application and you need to try again. The second option is to use the attached PNG file and insert it into a document yourself in something like word or publisher and play around with scaling until it prints perfectly (you will probably waste a lot of paper). You will need margins set very small to fit this on the page at full size. I haven't tested these myself yet but I have sized them against existing adaptors and they look perfect. I don't believe the GT86/BRZ needs the outer corner thickness reducing so the baffles can be a single thickness with a hole in the centre. For the last time: DO NOT waste time and materials cutting against this template if the scales don't match perfectly against a ruler or tape measure etc. If you've stumbled in here searching for baffles for a different model of Toyota then these might do the trick as well, this layout is used in multiple models. PDF File: Toyota-Speaker-Baffle.pdf PNG File: 3 WonkyJon, Tareim and mulletdevil reacted to this Share this post Link to post Share on other sites
WonkyJon 8 Report post Posted May 4, 2017 Thanks for creating and sharing this chap. I'm just getting started on the audio in mine and stuff like this is very helpful indeed! Share this post Link to post Share on other sites
Adam9 37 Report post Posted May 4, 2017 No worries, let us know how you get on! Share this post Link to post Share on other sites
Sean-A 8 Report post Posted May 4, 2017 Could put these onto the CNC machine at work and get a few made. Share this post Link to post Share on other sites
