keelerad 256 Report post Posted November 13, 2013 Well after a false start with some initial doubts about the fittings I have just fitted the bonnet struts that Fat Rab brought down with him that we got from Chris at Tarmac Sportz Note to get mine to fit like in the pictures on the other forum I had to mix the fittings, so Drivers side I used the one labelled L on the bonnet and R on the wing (see photos), checked operation and clearance when closing and everything seems good. Only tool you really need a 12mm ring spanner, though a ratcheting one helps to get to the bolts in the wings Did do the double spanner trick with a standard spanner though to crack it loose All done. look Ma no hands Nice easy fit, only the 4 bolts to undo 1 suggestable reacted to this Share this post Link to post Share on other sites
Special K 442 Report post Posted November 13, 2013 Alec, were these on a 'special buy' or something? Spec K Share this post Link to post Share on other sites
keelerad 256 Report post Posted November 13, 2013 Yeah he had a group buy going on Dan's Forum at £60 a set, seemed reasonable so I got a set Share this post Link to post Share on other sites
Lauren 2259 Report post Posted November 13, 2013 Looks like a good mod. :+: Share this post Link to post Share on other sites
Sideways? 33 Report post Posted November 15, 2013 what did you torque the nuts back up to?? Two grunts and a groan (i.e. FT - "f'ing tight")? or just quite tight? Share this post Link to post Share on other sites
keelerad 256 Report post Posted November 15, 2013 Just by hand quite tight as don't know correct setting for torque wrench but I'm checking them regularly Share this post Link to post Share on other sites
rob275 1817 Report post Posted November 15, 2013 I have chosen these as my prize from the Go Karting can't wait. Share this post Link to post Share on other sites
Special K 442 Report post Posted November 16, 2013 Yep, I like 'em. Not sure they'd be useful for me - I usually get the stable boy to open the bonnet and put his head on the block to prevent it closing... Seems that Fensport have some in stock.. Spec K Share this post Link to post Share on other sites
Kodename47 446 Report post Posted November 16, 2013 On 11/16/2013 at 8:13 AM, Special K said: Seems that Fensport have some in stock.. Not at all overpriced. Share this post Link to post Share on other sites
rob275 1817 Report post Posted November 16, 2013 We'll they are Greddy lifters, what do you expect really? Lol Share this post Link to post Share on other sites
benmmellor 44 Report post Posted August 10, 2017 bit of a thread revival - how have the ball sockets faired? Any signs of rusting? Share this post Link to post Share on other sites
Minion 132 Report post Posted August 10, 2017 I've had a set of these on for near enough three years now, not had one single problem with them. Would certainly buy again!! Share this post Link to post Share on other sites
benmmellor 44 Report post Posted August 10, 2017 On 8/10/2017 at 10:58 AM, Minion said: I've had a set of these on for near enough three years now, not had one single problem with them. Would certainly buy again!! which version - Greddy/GrimmSpeed/Speedline?? Share this post Link to post Share on other sites
Minion 132 Report post Posted August 10, 2017 On 8/10/2017 at 1:01 PM, benmmellor said: which version - Greddy/GrimmSpeed/Speedline?? Got them from Chris - Tarmac Sportz Share this post Link to post Share on other sites
Mike 458 Report post Posted August 10, 2017 Amber have them for £60 Share this post Link to post Share on other sites
benmmellor 44 Report post Posted August 10, 2017 but which ones are the least likely to rust ! ? Share this post Link to post Share on other sites
Minion 132 Report post Posted August 10, 2017 On 8/10/2017 at 1:35 PM, benmmellor said: but which ones are the least likely to rust ! ? Mine have nearly 3 years of use and show zero signs of rust... Share this post Link to post Share on other sites
