Donfrondo 1 Report post Posted April 12, 2016 Has anybody else had this problem and know of a fix? At motorway speeds the bonnet lifts on the driver side, I assume air is getting under the seal at the front and lifting it but the seal looks good and the bonnet sits down solid at the front when the cars static Share this post Link to post Share on other sites
Lauren 2259 Report post Posted April 12, 2016 They all do it. I wouldn't worry about it. Share this post Link to post Share on other sites
DanJ 374 Report post Posted April 12, 2016 The bonnets are aluminium rather than steel to save weight and help lower the CoG, aluminium is 1/3 the stiffness of steel for the same thickness so the air pressure at high speed causes the bonnet panel to flex down in the middle, which results in some lift at the edges the other side of the supports. As Lauren says its common to all our cars and not anything to worry about. Share this post Link to post Share on other sites
Nicebiscuit 655 Report post Posted April 13, 2016 Yep - worried me too but it's normal. Can't do much for the aerodynamics though! Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Willtl 54 Report post Posted April 14, 2016 My wife always tells me off for using sellotape for stuff. Have you tried sellotape? Drive some of the TVRs and then come back about bonnet lift. Share this post Link to post Share on other sites
Nicebiscuit 655 Report post Posted April 14, 2016 Or you could have one of those early TTs where the whole car took off at speed... Sent from my iPhone using Tapatalk 1 Mike reacted to this Share this post Link to post Share on other sites
Stutopia 158 Report post Posted March 15, 2017 Apologies for the old thread revival but I spotted this wobbling on the motorway just the other day and wanted to sort it. I thought I'd post up a solution of sorts in case anyone else stumbles across it with the same issue. Under the bonnet there are two rubber stops which the bonet should sit up against when closed. These little guys. If you give one a twist you'll notice they can be removed with ease and that they have a "spiral" cut into them. When I checked the bonnet you could see a noticeable difference in contact spots from the two sides. You can twist the stopper back on and keep twisting it up and down until you hit the desired height and hopefully end this wobbly bonnet blight 1 Church reacted to this Share this post Link to post Share on other sites
