Leosille
Spacers Temporarily Needed
Evening, I've just put my new wheels and tyres on and dodgy Rob forgot to mention that with standard suspension they will rub lol. Has anyone got some spacers I could borrow or purchase that they don't need, I'm in Coulsdon, Surrey. Thanks again Ryan.
Dodgy Rob I knew it😂😂
16 minutes ago, nikndel said:
While we are on the subject if I wanted to space out a set of wheels say by 10mm is there a safe way of doing this?
longer studs would be required for the type that just go over the current studs rather than giving you a separate stud to bolt onto
10mm are fine tbh, I used 10mm spacers with the same bolts, 15mm or more then you'll need longer ones. Just to chime in, I think he just needs 10mm for the fronts temporarily until he can get some aftermarket coilovers!
Slip on spacers are ok as long as you have enough available thread. For M12x1.25 studs the minimum is 8 turns.
One disadvantage with slip on spacers (primarily thin ones) is they aren't hub centric, which will mean the weight of the car is taken by the studs and not the hub.
