KubaNowicki
Gearbox noise
Hello my friends,
i am writting to you from Poland so forgive me my simple language.
I have the issue with my gearbox. It is identical like on this video:
 I have already changed the thrust bearnig and oil for Motul Gear 300 and now it is better but not ideal. Sometimes this sound is quiet but sometimes is loud.
Can anyone help me or give some advice?
Thanks!
Can you only hear it when you depress the clutch pedal? I couldn't quite figure out from the video. I can't think of anything obvious, if your car is still under warranty, it's worth taking it in.
Does it go away (get quieter) when the engine is warm and the gearbox has been used for a while?
Another check could be to gently move the gearstick towards each gear without using the clutch. Don't push it into gear, just push enough to 'feel' it begin to engage. You might find one of them makes the noise stop.
Mine does this when it's cold and if I 'touch' 3rd, then the noise goes away for a bit. For mine I assume it's just mechanical noise.
