Badger 63 Report post Posted December 11, 2018 Hi everyone. Does anyone know of a online parts catalogue / diagram site showing part numbers and diagrams. I'm looking to upgrade the aerial in my 2015 BRZ to dab and and wondering what exactly is different / required Sent from my LYA-L29 using Tapatalk Share this post Link to post Share on other sites
Dave86 33 Report post Posted December 11, 2018 I dont know if the BRZ has the same headunit as the 86 but if it's the same unit it's not as easy as simply installing an aerial, the Toyota solution requires a box installing behind the HU with new wiring and then an aerial on the windscreen. The part number for the tas300 HU install is here: Share this post Link to post Share on other sites
Badger 63 Report post Posted December 11, 2018 I've changed the radio to a pioneer dab item. Don't really want anything stick to the screen. I'm going to try a mag mount upside down in the bootSent from my LYA-L29 using Tapatalk Share this post Link to post Share on other sites
Dave86 33 Report post Posted December 11, 2018 The dab aerial for the 86 solution is absolutely tiny. I don't even notice it where I installed it on mine, too left of windscreen and i get perfect reception. Share this post Link to post Share on other sites
Badger 63 Report post Posted December 11, 2018 Do you have a picture at all? The dab aerial for the 86 solution is absolutely tiny. I don't even notice it where I installed it on mine, too left of windscreen and i get perfect reception.Sent from my LYA-L29 using Tapatalk Share this post Link to post Share on other sites
Dave86 33 Report post Posted December 11, 2018 Sure I'll take one for you in a bit! 1 Badger reacted to this Share this post Link to post Share on other sites
Dave86 33 Report post Posted December 11, 2018 1 Badger reacted to this Share this post Link to post Share on other sites
Badger 63 Report post Posted December 11, 2018 Thank you Dave. If my mag mount doesn't work then I will get one of theseSent from my LYA-L29 using Tapatalk Share this post Link to post Share on other sites
Badger 63 Report post Posted December 13, 2018 This arrived today and has been fitted to the right hand side of the underside of the parcel shelf. Gets the stations I want.https://www.dabonwheels.co.uk/product/kinetic-magnetwig-dma-1006/Sent from my LYA-L29 using Tapatalk Share this post Link to post Share on other sites
Badger 63 Report post Posted December 14, 2018 Drove down the road and signal cut out. Ordered a stuby roof mount to replace the oem shark fin so will report back when that had been fitted and wired upThis arrived today and has been fitted to the right hand side of the underside of the parcel shelf. Gets the stations I want.https://www.dabonwheels.co.uk/product/kinetic-magnetwig-dma-1006/Sent from my LYA-L29 using TapatalkSent from my LYA-L29 using Tapatalk Share this post Link to post Share on other sites
Badger 63 Report post Posted December 15, 2018 This one arrived today and after 3 hours it was fitted and all workinghttps://www.dabonwheels.co.uk/product/kinetic-dra-6003-stubby-dab-dab-fm-sw-mw-lw-car-aerial-2/?attribute_bundle-options=Kinetic+DRA-6003+stubby+DAB%2FDAB%2B%2FFM%2FMW%2FSW%2FLW+car+aerial+-+DAB%2FFM%2FAM+bundleDrove down the road and signal cut out. Ordered a stuby roof mount to replace the oem shark fin so will report back when that had been fitted and wired upSent from my LYA-L29 using TapatalkSent from my LYA-L29 using Tapatalk 1 Dave86 reacted to this Share this post Link to post Share on other sites
OllyW 9 Report post Posted December 15, 2018 Just for reference here's a service manual should you ever need it It's for the FRS so Audio may be slightly different and obviously it's LHD instead of RHD but it's the closest publicly available https://demos.starbase7.net/t3Portal/resources/jsp/siviewer/Scion_FR-S_2013_rm_index.html 1 Badger reacted to this Share this post Link to post Share on other sites
