MartinT 514 Report post Posted October 14, 2019 The fuel trims have greatly helped drivability and the car is easier to control at traffic crawling speeds now. Once properly underway, it feels much like before except there is response to a decent prod at any speed in any gear. It almost never needs flooring - just a good prod and the speed builds quickly, something I remember my supercharged Honda doing. I honestly wouldn't want or need more power than this. It's very well matched to the chassis. Will report on average mpg once the gauge has settled into a near-final reading. 4 Subota Boy, BRZ-123, spikyone and 1 other reacted to this Share this post Link to post Share on other sites
MartinT 514 Report post Posted November 12, 2019 In today's winter sun. 4 Lauren, Jay, Varelco and 1 other reacted to this Share this post Link to post Share on other sites
MartinT 514 Report post Posted November 24, 2019 I've just received the badge from Harrop so it's gone on the car. Finishing touch. 4 Subota Boy, matrixprotein, spikyone and 1 other reacted to this Share this post Link to post Share on other sites
MartinT 514 Report post Posted January 2, 2020 A few things: the economy has settled to around 30.6mpg. It did hit a high of 30.8, but in this nice weather I've been using the power a bit more again. The supercharger installation is running very smoothly and I think it likes the cool intake air, which is running at +14 (so 22C today). The rear tyres are really wearing much faster than the fronts now with the supercharger, it's reminiscent of my old BMW in that respect. I should probably rotate them to even things up a little. I had a Golf right up my backside this afternoon. Dropped it to 5th and hoofed it. Nope, wasn't losing him so I pulled aside in the next gap. It was a Golf R. Oh well, can't beat them all! 3 BRZ-123, Notaricer and Angelina reacted to this Share this post Link to post Share on other sites
