BRZ-123 174 Report post Posted January 21, 2020 On 1/21/2020 at 3:26 PM, MartinT said: Good news - it was just an exhaust blow in the TD super resonator, the crack being opened up under load and with revs. Phew, what a relief! I've got the 3-bar MAP sensor installed and Mark is just sorting out low rev fuelling to make it a little smoother on pulling away. I shall enjoy driving it home!Great news and glad its nothing serious. Did the exhaust crack due to additional load the SC is putting or due to an impact with a foreign object? Sent from my SM-G970F using Tapatalk Share this post Link to post Share on other sites
MartinT 514 Report post Posted February 1, 2020 6 1 Deacon, SimonG68, Willson777 and 4 others reacted to this Share this post Link to post Share on other sites
James7 14 Report post Posted February 16, 2020 On 2/16/2020 at 6:08 PM, MartinT said: Functionally, I am impressed with the Eonon which is responsive and runs the Android apps I've tried without any problems. The 7" and 10" should behave identically. Do Android head units such as these allow you to run the Torque app and show gauge dials on the stereo screen (either by installing the app directly onto the head unit, or mirroring from your phone)? Share this post Link to post Share on other sites
Deacon 1357 Report post Posted February 16, 2020 On 2/16/2020 at 10:23 PM, James7 said: Do Android head units such as these allow you to run the Torque app and show gauge dials on the stereo screen (either by installing the app directly onto the head unit, or mirroring from your phone)? Yes Share this post Link to post Share on other sites
