CherryBomb 34 Report post Posted November 3, 2019 I was looking up youtube videos about 6 speed vs 5 speed transmissions and what the differences are. I'm trying to learn everything I can so I understand my car. Sometimes I think, what exactly is the point of the 6th gear? lol. I'm sure some of you are rolling your eyes. Well, I clicked on one video, and there was a about a ten-second intro with some text and the sound of a car starting up and running. I thought, that sounds like a GT86! And sure enough, when the video started, it was! I definitely do not have a trained ear for different cars, but this car really does have a unique sound! 1 Angelina reacted to this Share this post Link to post Share on other sites
Jay 37 Report post Posted November 3, 2019 The sound is quite unique. It's a combination of the high revving four cilinder boxer engine and the exhaust system. Regarding the sixth gear, I think it's mainly there to reduce fuel consumption at constant speed, as well as getting a better environmental rating. 2 CherryBomb and Angelina reacted to this Share this post Link to post Share on other sites
MartinT 514 Report post Posted November 3, 2019 Sixth gear is good for motorway cruising - reduces noise and improves economy. It's not what the car is about, but if you use it on your daily commute as I do (60 miles per day), then it's important, too. Agreed about the sound, the boxer engine does have a lovely rumble. 1 CherryBomb reacted to this Share this post Link to post Share on other sites
Twigman 93 Report post Posted November 4, 2019 15 hours ago, CherryBomb said: what exactly is the point of the 6th gear? I often find myself looking for a 7th gear, particularly on the motorway, in Germany, at about 90mph 1 1 Angelina and Jay reacted to this Share this post Link to post Share on other sites
CherryBomb 34 Report post Posted November 5, 2019 On 11/4/2019 at 9:54 AM, Twigman said: I often find myself looking for a 7th gear, particularly on the motorway, in Germany, at about 90mph LOLOLOL Share this post Link to post Share on other sites
Twigman 93 Report post Posted November 6, 2019 14 hours ago, CherryBomb said: LOLOLOL What's funny? The GT86 is seriously short geared for high speed motorway cruising. Share this post Link to post Share on other sites
Church 209 Report post Posted November 6, 2019 hmm, short geared? AFAIK at top speed of 145mph/233kmh (don't recall though if drag or ecu tune limited) one won't even reach redline, no? All extra cog may net (that is if limited (if stock NA) engine power will be sufficient to overcome drag at top speed but even lower rpms), improve a bit fuel economy and lower a bit noise, which still be very high due little sound insulation/tire noise/high speed wind noise, not from engine only. Otherwise it's gearing does the job improving acceleration down low. I'd think of longer gearing .. probably at most if went forced induction. Share this post Link to post Share on other sites
Twigman 93 Report post Posted November 6, 2019 12 minutes ago, Church said: hmm, short geared? It could do with a 7th longer gear.....keeping the 6 it already has. Cruising at 90-100mph (140-160kph) puts the engine right where I don't want it (MT). It has GT in the name, which stands for 'Grand Tourer' in most peoples' dictionaries.....it should be capable of doing some 'grand touring'. Clearly the designers had 70mph cruising as their priority when selecting the top ratio - some of us like to cruise a bit faster. Often 70mph feels like I could get out and walk faster. Perhaps I crave an Aston Martin? 1 Jay reacted to this Share this post Link to post Share on other sites
Jay 37 Report post Posted November 6, 2019 I don't think there's enough torque for cruising at high speed with an even longer gear ratio. Share this post Link to post Share on other sites
Twigman 93 Report post Posted November 6, 2019 5 minutes ago, Jay said: I don't think there's enough torque for cruising at high speed with an even longer gear ratio. Of course there is - you don't need oodles of torque to maintain a constant speed. Clearly none of you have driven cars from the 60s or 70s that couldn't pull the skin off a rice pudding but could do 70mph with no problem. Share this post Link to post Share on other sites
Jay 37 Report post Posted November 6, 2019 27 minutes ago, Twigman said: ...Clearly none of you have driven cars from the 60s or 70s that couldn't pull the skin off a rice pudding but could do 70mph with no problem. I'm not talking 70, I'm talking 120+. The slightest climb or headwind will force one to shift down to maintain speed. Share this post Link to post Share on other sites
Twigman 93 Report post Posted November 6, 2019 1 minute ago, Jay said: I'm talking 120+. and I was talking 90-100 120+ cruising is just not possible, even on the autobahn. The roads are too crowded. Share this post Link to post Share on other sites
Church 209 Report post Posted November 6, 2019 Also aero drag and power to counter it grows at very high rate. So even if 70mph doesn't look that much slower then 100mph, drag (and power required) differs a LOT, so not sure, if worth to compare with cars/power/speed of past. From wiki, if car cruising at 50mph needs 10hp to counter aero drag, 80hp - to counter drag at speed of 100mph. Share this post Link to post Share on other sites
Twigman 93 Report post Posted November 6, 2019 39 minutes ago, Jay said: I'm not talking 70, I'm talking 120+. The slightest climb or headwind will force one to shift down to maintain speed. and that would be a problem, why? As it is we're running at uncomfortably high revs on the level or downhill. Share this post Link to post Share on other sites
86iain 44 Report post Posted November 6, 2019 I'm happy with mine on a motorway.It's sits happily thrumming away for hours.Sent from my VFD 710 using Tapatalk Share this post Link to post Share on other sites
Jay 37 Report post Posted November 6, 2019 16 minutes ago, Twigman said: and that would be a problem, why? As it is we're running at uncomfortably high revs on the level or downhill. Suddenly I understand why we have different opinions about a 7th gear. My GT86 has an automatic gearbox, which has a significantly longer 6th gear: 0.760 manual, against 0.582 automatic. An extra gear wouldn't hurt the manual version. 😉 Why I chose an automatic? I've been driving cars with automatic gearbox for almost 25 years, because of arthritis which from time to time affects the lower spine, making it painful to use a clutch pedal, specifically in traffic jams. 😐 Share this post Link to post Share on other sites
Twigman 93 Report post Posted November 6, 2019 4 minutes ago, Jay said: An extra gear wouldn't hurt the manual version. 😉 Thank you. At last someone agrees with me! I couldn't accept that I was the only one! Share this post Link to post Share on other sites
Jay 37 Report post Posted November 6, 2019 7 minutes ago, Twigman said: ...I couldn't accept that I was the only one! Maybe I'm the only one on GT86.org.uk who drives an automatic, paddling through the gears. 😁 Now I feel so terribly lonely! 🤣🤣🤣 Share this post Link to post Share on other sites
Leeky 84 Report post Posted November 6, 2019 1 hour ago, Jay said: Maybe I'm the only one on GT86.org.uk who drives an automatic, paddling through the gears. 😁 Now I feel so terribly lonely! 🤣🤣🤣 I’m also running an Auto 86 1 2 Jay, Rocket Panda and gazza82 reacted to this Share this post Link to post Share on other sites
Lauren 2259 Report post Posted November 6, 2019 5 hours ago, Twigman said: It could do with a 7th longer gear.....keeping the 6 it already has. Cruising at 90-100mph (140-160kph) puts the engine right where I don't want it (MT). It has GT in the name, which stands for 'Grand Tourer' in most peoples' dictionaries.....it should be capable of doing some 'grand touring'. Clearly the designers had 70mph cruising as their priority when selecting the top ratio - some of us like to cruise a bit faster. Often 70mph feels like I could get out and walk faster. Perhaps I crave an Aston Martin? I don't get this. I've done four long Euro trips in my car including desestricted autobahn on all of them. I think the gearing is ideal. I don't cruise over 80 in this country but the car with the gearing it has is happiest cruising at 100mph. At 90 it's great too as you are well into the torque band of the engine so it picks up really well to about 110mph. Far better than it does at 70mph in 6th gear. Over 100mph fuel consumption really takes a hit I find. On derestricted autobahn I cruise between 100-110mph which is fine. I'll have the odd run over 200km/h (120mph) and beyond where there's space. I do tons of long distance driving in my car, only went from Manchester to London and back yesterday, it handles it really well. I wouldn't want the gearing to be longer. Still returned 43.6mpg as well which is good enough I think. 1 SimonG68 reacted to this Share this post Link to post Share on other sites
gazza82 41 Report post Posted November 6, 2019 3 hours ago, Jay said: Maybe I'm the only one on GT86.org.uk who drives an automatic, paddling through the gears. 😁 Now I feel so terribly lonely! 🤣🤣🤣 I've got a BRZ auto ... fun with those paddles! 3 1 Leeky, SimonG68, Rocket Panda and 1 other reacted to this Share this post Link to post Share on other sites
SimonG68 71 Report post Posted November 6, 2019 Mee too with Auto 86, love it...Sent from my iPhone using Tapatalk Pro 3 1 Leeky, Deacon, Rocket Panda and 1 other reacted to this Share this post Link to post Share on other sites
Rocket Panda 175 Report post Posted November 6, 2019 Auto 86 too....I'm loving it! 😁 Don't feel lonely Jay.....plenty of us on here paddling through the gears! 3 1 Leeky, The Minion, SimonG68 and 1 other reacted to this Share this post Link to post Share on other sites
Jay 37 Report post Posted November 6, 2019 Great! It's like we could start an auto club within the drivers club. 😁🤣 2 1 Leeky, Rocket Panda and SimonG68 reacted to this Share this post Link to post Share on other sites
Twigman 93 Report post Posted November 7, 2019 16 hours ago, Lauren said: I don't get this. I just find that in 6th at high continental cruising speed it feels like it would be more comfortable with a few hundred fewer revs. I often find myself reaching to change up when I'm already in 6th. Share this post Link to post Share on other sites
