MLC22 4 Report post Posted August 18, 2020 Hi guys and gals. whilst perving in the engine bay I noticed the clutch oil is pretty low. As this is the first Toyota Iv owned just wondering what is the best to use? thanks Share this post Link to post Share on other sites
Conscript 45 Report post Posted August 18, 2020 Pretty sure you can just use brake fluid, DOT4 should be fine... It might even state it on the filler cap. Share this post Link to post Share on other sites
MLC22 4 Report post Posted August 18, 2020 On 8/18/2020 at 4:13 PM, Conscript said: Pretty sure you can just use brake fluid, DOT4 should be fine... It might even state it on the filler cap. On the filler cap just says brake fluid, donโt state which grade. I do have some Mobil dot 4 about so may top it up with that then. ๐๐ป Share this post Link to post Share on other sites
gazza82 41 Report post Posted August 18, 2020 It will be brake fluid ... Dot3 minimum so Dot4 is fine (actually better and easier to get now). Share this post Link to post Share on other sites
BRZ-123 174 Report post Posted August 19, 2020 Always check the user manual first. And the above answers are right. I would not recommend you to use old fluid as its hygroscopic and has a limited shelf life , once opened. Sent from my SM-G970F using Tapatalk Share this post Link to post Share on other sites
MLC22 4 Report post Posted August 19, 2020 On 8/19/2020 at 4:53 AM, BRZ-123 said: Always check the user manual first. And the above answers are right. I would not recommend you to use old fluid as its hygroscopic and has a limited shelf life , once opened. Sent from my SM-G970F using Tapatalk Thanks mate. I will go buy a new bottle then and just top up. appreciate the helps guys Share this post Link to post Share on other sites
