Adi
Crawford Performance Intake Manifold Spacer (Billet Power Block - BPB)
New, genuine, bought from US, never installed.  £325
Significantly improves the drivability of the stock car.  Installs in an hour or less. Will not affect MOT, etc.
Best NA power mod if you do not want to go the manifold + tune  route, which is several times more expensive.
Independent review here: https://motoiq.com/tested-crawford-performance-fr-s-brz-power-blocks-intake-manifold-spacers/
* Improves OEM Torque Dip by 300 RPM on a Totally Stock BRZ
* Improves Acceleration
* Decreases Delay between Shifts with AT
* Increases the Volumetric Efficiency of your Intake Manifold
This is the real thing, not the cheap imitations you see from other sellers. It cost me around £400 including import duties and VAT.
