Church
    13
Church last won the day on October 4 2022
Church had the most liked content!
1 Follower
About Church
    Senior Member
  • Birthday 05/16/1978
    Riga
  • Interests
    reading, PC liquid cooling, anime, manga, unix, GT86 & drifting :)
5829 profile views
  1. Church
    DAB radio upgrade
    Out of curiosity, which android headunit? How much it ram it has, which android version, does it have physical knobs, what is audio quality?
  2. To prevent potential injuries to someone sticking head or hand out of window, modern car window lifters incorporate check, to if they have some hardship rising window, on detecting of which they stop and go into this mode of not closing completely, and on twins it's also indicating with flashing window operating buttons. Not that uncommon to see in winters if glass is frozen to seals (advise to use some rubber conditioner eg. gummipflege to reduce frosting to). Weird to see it happening not in winter. If windows lifting mechanism didn't work after reset trick (btw, no need to wait that long as 15s, just with closed doors press and hold it 2-3s past it lowered, and then press to rise and hold 2-3s past it rised. If worked, should be observable right away, with buttons not flashing anymore, and windows operating normally), then i guess yes, something might be wrong and worth making a trip to dealership. (BTW, my memory is a bit vague on this, frozen glass to seals didn't yet happened for last years since started using said gummipflege, but it's also possible, that one needs to use the switches on door, whose window lifting controller needs to be reset)
  3. Changing rake can change a bit weight distribution & aero balance. I guess lowering front more, will make it less understeery. Then again, if that matters a lot like on track, more then possibly one has several other means/mods to change that, eg. more track fit alignment, or aero upgrades. I probably wouldn't overthing too much this rake change.
  4. Church
    Tuning/Mapping advice needed
    Not sure there is something "to regret". But if one has aftermarket catback, most of those are annoyingly (also for neighbors) loud with cold start. If stock catback, imho it's not an issue. And a bit easier/quicker to heat up cats prior MOT. But not having it of course will bring no unsafety to engine. Linear throttle map .. it's subjective thing. It may provide a bit finer throttle control on track .. but also with it engine might feel a bit weaker, after all, non linear was implemented especially to fool one's mind, that there is more powerful engine then it is, as most drive on public roads with partial/lightly pressed throttle, so if engine power changes a lot relative little initial throttle pedal movement, it seems more powerful subjectively. Some may like it, some not. Then again, probably you'll be tuned via ecutek? Then probably you can have several tunes, with/without coldstart, with more linear or as stock throttle mapping, various fuel types and so on, and be able to switch between tunes (via eg. cruise control stalk).
  5. Church
    Big end bearing failure
    Out of curiosity, what mods you have (or haven't) done to oiling?
  6. Church
    Replacement Head Unit Which/Installation?
    I just relocated with adapter cable off back of headunit usb ports to inside of glovebox. Thought line goes like this, that anything plugged in clear sight (such as in usb ports in centre console) will extra motivate thieves to break in. And constant plugging in/out whenever i leave car imho redundant hassle.
  7. It's ok for some firm to have temporary problems/issues with timely work with customers due that .. but at very least it looks to be handled very poorly, in way that will leave long lasting damage to reputation.
  8. Even with redline as is FA engines imho are "revvy" enough, way more so then average family car engines with redline ~ 6K. And those very few engines that did rev higher, eg. in S2K AP1 were replaced with torqier but with slightly lower redline in AP2. So imho revvy & sporty by my taste enough. As for lightening car .. i'd think of complex solution. Both slight power increase (via eg. ecu tune & catless header. or going supercharging route), and lightening (removal of crap in boot, deletion of rear seats, replacing heavy stock seats with light bucket seats, replacing heavy battery with l/w Li one, installing smaller washer fluid tank, installing lighter wheels & BBK. Doing these imho should retain most of comfort features.
  9. Church
    Possible to lean seats back?
    Use lever in front/below of seat to move seat up or down. > Pump several times seat frontmost side lever to lift or lower seat. Pull rearmost side lever to unlatch back of seat, release when reclaimed back of seats at needed angle. Use latch below steering column to unlatch and adjust via tilt up/down or telescopic towards/from you steering wheel. If seat & steering wheel adjustment ranges are still not able to get you in right & ergonomic position and you have to eg. compromise between headroom (especially matters when wearing helmet in eg. trackdays) that may require more reclaimed rearwards back of seat to gain headroom, which may put steering wheel too distant even in rearmost adjustment position, you may consider steering wheel spacer and control stalks extenders. As alternative, one may consider aftermarket bucket seat that sits lower and gains headroom this way. Might be compromised ease of getting in rear seats, functioning of side airbags and seat heating though.
  10. Church
    Folding mirrors/'One touch' indicators
    Indeed so. They don't automatically fold. Buy/install this for that function. Then mirrors will fold when you lock the car, and unfold, when you start engine. Subaru P/N H2717CA000 https://www.japanparts.com/parts/detail/44085 install manual (in japanese unfortunately) http://home.bullet-systems.com/webscratch/gt86/H2717CA000.pdf probably there is something to change blinker function, but never felt need for such function, thus never searched info for such
  11. Church
    Flywheel issues on my GT86?
    Maybe record it, post vid somewhere to listen
  12. Church
    Bonnet vents
    There were tests/data by CSG. They do obviously reduce underbonnet temps. In addition to that vents also reduce front-end lift, which also seems beneficial, as imho is similar to rear diffuser, adding a bit downforce to front w/o much extra drag, and w/o having to compromise ground and front's geometrical clearance, that lowering/splitters and alikes do.
  13. Church
    Sell With or Without Mods
    Better price for "stock" car obviously. Another reason why i keep OE when upgrading anything to aftermarket and prefer reversible mods. One hardly will get even 1/4-1/3 of mod parts price, but car's price itself usually can be made noticeably higher.
  14. If car is NA i find it unlikely to have issues with rods even if abused. If overboosted with FI non built engine w/o forged internals .. but imho one can fsck up engine in this case irrelevant of FD ratio. Short gear ratio gearset + FD is what i'd love to see in mine (so that 1st & 2nd gear stays somewhat same, but other gears come closer down). Pitty that especially former costs more then i'd willing to pay for that.
  15. Church
    Autobahn fun
    Twins can go even faster then that, but IIRC top speed was limited in ECU (more so in JDM one, to ~180kmh). I guess, engine & roadnoise at such speed was not exactly enjoyable? As for stability .. it also greatly depends on alignment of suspension. If it's out of whack (especially toe), it may behave differently.
