Moro
About Moro
    Latvia
  • Interests
    Tinkering in the garage mostly
    Hot lava
1447 profile views
  1. Two have small marks, two are worse. This is the worst one: q2
  2. You might of course say I'm biased being a seller but Jevvy makes a good point. For what it's worth my Eibach 20 mm spacers weighted less than 500 grams all in with studs and nuts (and they made up a big part of spacer's mass being steel). Purely speculating a 25 mm spacer would be no more than 600 grams which would make a 6.8 kg wheel all in, still much lighter than most wheels out there.
  3. I've imported these for my 86 but now the turn of events means I'm selling up and the wheels are for sale too. They are Rays Volk CE28N 17", 7.5" wide and with +50 offset. Being proper forged Volks they're incredibly light at only 6.2 kg a piece! All are straight and true, haven't been welded/repaired or bear any other defects apart from quite noticeable kerbing. Still in original Volk factory finish - matte anodised spokes and polished anodised lips. If you click on a picture you'll be redirected to Flickr where you could zoom in and see their condition in detail. They're not show wheels but you'll struggle to find anything stronger or lighter. I'm after £900 ONO. Tracked delivery with DPD from Riga to mainland UK would be £50 and take 5 work days. Thanks for looking!
  4. Moro
    My 86 Aero
    Long time no updates, but not much to write about too. Somewhere around Christmas we've had a few days holiday planned, 300 or so miles away from home. And literally two days before leaving home a front damper went bust in my other half's car, making for a pretty interesting handling. I couldn't source a replacement quickly enough and didn't want to take a risk of driving the car on motorways and we had to resort to 86 for the family trip. My wife was hesitant at first but it turned out much better than she expected, with my 10 year old son seated in the back and her in the front they both were comfortable enough for the length of the trip. And I've had a bonus of little RWD antics on the way back home when it started snowing. With most of the spring and summer spent driving the MX5, Toyota was left a little neglected and ended up looking really rough, the sealant it had on (Carpro Reload) had deteriorated up to the point the car was attracting all the dirt and looked a mess. It was time to sort it out. Now, it's only recently that I've got into detailing and I certainly prefer driving over looking good, so don't expect any show-worthy results As for the process, washed it with snow foam, then two bucket method. Used a polyshave block for claying. Very much recommend it, much easier to work with compared to normal clay and if you drop it on ground, no biggie, just rinse it and go on. Then degreasing and light polishing with Meguiar's 205. Purposely avoided heavier polishing as being a winter commuter the car sees so much crap that to keep it impeccable I'd have to heavy polish it once a year if not more often and I'm afraid I'd be soon left with no lacquer left to polish. Another wash after polishing and a coat of Soft99 Fusso synthetic wax.  Interested to try it out as it's supposedly long-lasting, which is important for a car I use daily between November and April, as there is no chance to detail it once a month or so, so I'm looking at something which will last as long as possible with very regular snow foam washing. Finally, cleaned up wheel lips with Autosol and that's what I've ended up with.
  5. Moro
    Lauren's AE86
    The car is absolute beauty! I suppose when the whole point of the car is fun and balanced handling, suspension setup draws the line between a crap and an excellent car. Great job on making it the latter. Your testing grounds look awfully familiar, I bet AE86 is a hoot to drive there, but I've heard they've put lots of speed cameras there lately? Lastly, hope I'm not speaking out of my arse, but when comparing spring rates, are you taking into account differences between motion rates in ZN6 and AE86 suspension designs? I suppose there isn't much in it at the front as both run MacPhersons, but what about the rear? And did I tell you, the car i stunning!
  6. Moro
    My 86 Aero
    Now lowered on Pro-Kit and with 225/45 Falken tyres on
  7. Moro
    My 86 Aero
    The finishing touch to the wheels, all the necessary decals finally came in the post and were duly applied. I think I will put some 225 tyres in the spring though, as the factory Primacies have such a massive rim protector they look aggressively stretched when in fact they are not. But this car is all about fun driving it and on this note I went to a local autodrome a few weeks ago to have some. It was all good, the track is small with tight turns, more of a karting track really and it was nice to slide around, this no doubt helped by intermittent raining. Though expected but still a little irritating it was to find how the car understeered on initial turn in. It was especially apparent as I had a chance to try out the new MX5 back-to-back and while being much "wallowier" it was actually turning in with more want, this probably helped by it's lighter weight too. So this Saturday I finally came about to sorting it out and went to an alignment place. First we've checked the settings and it was in factory specs, around zero camber in front and about zero toe front and back. Tried what's possible with factory adjustments and as expected couldn't get more than a half degree camber in front, so astutely bought Powerflex camber bolts came out of the box and were put in place to give the desired 1 degree camber angle. We've also dialled a slight toe out (0*04' each side) in the front and adjusted rear for precise zero toe. While I haven't had a chance to go to the track yet, the difference is even apparent on the roads, especially doing 180 degree turns, the car does turn in much better. A little change maybe but a tangible one at that.
  8. Moro
    My 86 Aero
    Cheers everyone! Haha, it would probably!
  9. Moro
    My 86 Aero
    You do know your wheels! They are S1's indeed, in 17x8 guise. And I hope they will come alive with the Eibachs on.
  10. Moro
    My 86 Aero
    A little update The wheels took a lot of work but finally they are done. They will have to wait until spring as I don't want to risk ruining them with road grit in winter, but I've put them on for one evening and a asked a mate to make a few snaps. Ride height does look slightly silly but it will be sorted in spring, I already have a set of Pro-Kits sitting on a shelf. Otherwise I think they are a good compromise between looks and keeping the driving character of the car intact.
  11. Moro
    AUTOSPORT 2016
    I'm in UK on these dates so will see if I could get there on Sat.
  12. Moro
    Toyota S-FR coupe
    I like it. And I like the fact the Toyota is back making sports cars. Of course it's far from the sweet 90's when every major Japanese manufacturer produced a few sport models, but it is a step in the right direction. Now Nissan, maybe you would reconsider abandoning the IDX project?
