Newmans
About Newmans
St Neots
Fondmetal 9RR Alloys with Yokohama V105 for sale
Newmans replied to Newmans's topic in For Sale GT86 / BRZ Parts
Sold -
Now on ebay -
Sensible offers considered. Picture as fitted to standard GT86 -
Newmans posted a topic in For Sale GT86 / BRZ Parts
Set of 4 alloys and tyres for sale.Alloys:Fondmetal 9RRSatin black17 x 7 ET45CB 56.1 (fits standard hubs with no need for spigot rings)These weigh 7.45kg so a saving vs standard. See pics below for comparison of standard wheel and primacy vs these alloys and Yokohama2 of the alloys have tiny kerb marks which may just be visible in the photos. So tiny I just touched in with black paint.Tyres:Yokohama V105 extra load 215/45/ZR17/91YTwo about 5mm, one 4mm, one 3mm treadCentre caps and wheel nuts included both with a little corrosion as seen in the photos. Location: St Neots, CambsPrice: £300, pickup only due to size and weight. -
Knightryder - tried multiple logcfg.txt files from the standard ones downloaded with ecuflash to others located on ft86club. Also two microsd cards. Also stripped down logcfg with just IAM. Also with and without triggers. Also checked logcfg with hex editor. Pretty sure the connection is OK since I can pull the ROM and a cheap ELM327 Bluetooth device works with torque app. I think I'm on latest firmware (limited documentation so hard to be sure) so I'll investigate your comment about the new firmware upgrade. Overall objective was to confirm IAM and MAF scaling for which I need logging - I think. Thanks Steve
Gringosteve - I applied the A01G STD map first (mine was A00G, dealer said this was the latest but I knew it didn't have DI injector seal fix which bugged me) then applied the OFT STG1 map using romraider to check tables before applying the map. That aspect seems to work fine but documentation is limited so you spend a lot of time looking for info on other websites. You can't switch maps like ecutek but my car is standard so wasn't bothered by that. Quite nerve-racking when you apply the first map but once you've done it you stop worrying! I liked the ecutek solution but software and licence seem expensive when you're only making small gains on a standard car. Rgds Steve
Having trouble getting standalone logging working on my new tactrix openport cable (flashing and reading work OK). Anybody else using tactrix and able to offer suggestions or show me working solution? Rgds Steve
