Lundster
About Lundster
    Cheshire
    Pearlescent White
  1. Lundster
    Valenti rear bumper light
    Managed to sort mine out finally. I had followed a guide a couple of years ago where the blue wire from the socket of the valenti is taken out and added to the blue wire for the tail lights. This blue wire is the wire for the normal running condition. The red is the brake. So I put the blue wire back into the socket: I then moved the red wire of the bumper light from the red wire of the tail light and moved it to the blue wire instead: Now this here is the internal wiring I have: You will need to unsolder the blue wire and the black and orange and solder them all together like so: Wrap with electrical tape or use heat shrink if you have it. Now it should function in line with UK law; the fog light will turn on with the fog light switch, the V will work with the normal lights, and the reversing lights working as normal. I've also added this to that Aussie post. Hope this helps some people out!
  2. Lundster
    Ksport 330mm 8 pot torques and rewind tool
    Thanks!
  3. Hey guys, I'm going to be renewing my front ksport rotors and brake pads with ksport rotors and ebc red stuff pads. Current setup: Ksport grooved 330mm rotors Ksport 330mm 8 pot calipers (yellow) Ksport brake pads Front wheels are work emotion cr kiwami 18" I have no idea what the torques are and not sure what kind of rewind tool I'll be needing. Anyone out there that has the same brake kit and happens to know the torques and rewind tool required? If this is the wrong section then I'll move it. Cheers for any help
