Chess010
Chess010 last won the day on April 22 2020
Chess010 had the most liked content!
About Chess010
Macclesfield
Yellow
Chess010 started following Cigarette lighter no power
Can anyone advise where is the location on the fuse and numbered position if in fusebox at drivers side here is photo of centre console on my gt86 giallo For some reason I now have no power at this location .use cigarette lighter for other attachments needing power . am assuming fuse has blown
Toyota 2015 GT86 Limited Giallo Edition - 2.0 L D-4S 200 bhp Petrol - 25,000 miles
Chess010 replied to ganesa's topic in For Sale GT86 / BRZ Cars
How much is this car? -
If you leave it on trickle charge all the time while we have this virus am sure it will start no problem
Seems odd started then cannot now do so would it be worth disconnecting leaving fir few minutes then reattaching lead and charging again and see if then is ok if get working again would take to local car shop or garage and get them to check battery and if faulty contact manufacturer of the battery if still under warranty
The adapter lead will only work if it is a ctek 5.0 charger I think. It is available on amazon. I goes from battery outside the bonnet and is permanently attached to battery terminals and is a little plug that I leave sitting on the area just below windscreen outside the bonnet. It is not obtrusive .I can recommend this ctek 5.0 charger available on amazon so search for the attachment which is cheap and also the charger
Hi am glad you finally got into car. as I said it is a sudden freeing although i never had need to resort to allen key to aid movement although it would probably have helped me.I said before I got a CTEK charger along with this from amazon. well worth it as now can charge car anytime without need to get into car as this lead is always attached and jus need plug in to CTEK 5.0 charge unit. if your car is still under warranty I would get in contact with toyota head office- hopefully they can still reply and tell them failed battery and hopefully gain a second one replaced under warranty. but if not get it checked out by local garage and if faulty there is usually a 3 ,4 or even 5 year warranty from the battery manufacturers and contact them to get their response. -worth doing a check on battery even if seems to be holding charge CTEK Indicator eyelet M8: practical LED indicator for immediate indication of battery charge levels by CTEK
T
As a last resort you may find one of your local small garages may come -assuming still working as believe some are but all main dealers closed and for a price of course . Could try with mole grips or similar to hold key but think you could end up using too much force. Hopefully leaving WD40 overnight in lock will help- go out and add some more! Also as a final try see if after leaving for overnight try the fob again in case there is just enough power left in battery
I mean wiggle very very small amount clockwise then anti-clockwise you hardly think it’s worth it but it then came free or at least did for me . Gentle rocking as fast as you can but not forceful put plenty of wd40 down before you start . Your problem seems harder than mine but I’d did come free and when it did it was sudden not sure can give any more help am afraid . Warm the key first? Or gently warm wd40 but take care don’t want to set it alight. Do not want to heat bodywork as may damage paintwork. Call out aa or rac? Assuming they are still working phone tonight and hope they can come by tomorrow that’s my only other suggestion although might find they cannot get open either. Do not use you much force as if break key in lock would make it even harder to get into. Don't know any burglars!!! They would get in no problem
I found that you just have to keep persevering lubricate by squirting wd40 into lock by letting it dribble down from the key and then keep on wiggling key fractionally clockwise and anti-clockwise it may take 15 or twenty minutes and you think you are getting nowhere but then it suddenly releases. It’s very odd but do not stop keep on trying as described and am sure it will unlock then charge car. i have a ctek 5.0 trickle charger along with attached cable available as accessory that Is permanently connect to battery and the end is sat outside bonnet next to glass and then no need to get into car if battery fails let us know how you get on
Thanks for info and hope your battery is ok dealer should change to 65 amp if you have a problem
What made them think it was power drain from the alarm i have been trying to find out why battery failing and wondered about power drain from somewhere did they measure the alarm outputs let me know outcome
Keep on turning moving gently for ten minutes or so and it should work. I had this happen and it will suddenly free. Seems strange but it can take this long continuously moving ever slow slightly left and right then if under warranty get free replacement battery preferably 68ah or higher
as a lot of members have issues with the batteries on GT86 is it possible for administrators to arrange to get a lot of signatures to sign a petition collectively to send a complaint to Toyota to sort this out as it is terrible brand image and problem for a lot of owners and if petition was made from a lot of people they might listen to everyone. Toyota used to stand for reliability as one of major importance to car buyers but not anymore IMHO.
Batteries should be "Fit for purpose" but it seems Toyota get away with this bad practice
Hi Move the key in the lock turning it few mm a bit at a time for around 10 minutes continuously and it will probably then suddenly turn and open at least thats what happenened to me. it seems very strange you think nothing is happening but then it suddenly works . keep on trying but careful so as not to bust so even almost nothing turning keep on trying clockwise and anti clockwise back and forth and see what happnes after 10 minutes
