Swinginking
About Swinginking
Info needed : Gap size between Roof and Roof-lining
Swinginking replied to Swinginking's topic in Modifications
Ill check that build thread out, thanks! -
I need to sound deaden it, so wondering what material would be idea to use + how many layer I can do etc etc -
Hi, Without me tearing apart the car to check, does anyone have an estimate of how big the gap roughly is between the roof lining and the actual roof? Thanks
Well... Nevermind guys, some opportunist theif stole them off my car while I was shopping.
I'd suggest calling a independant garage nearby and just asking. They might charge you £10.00, I've done that in the past with no problems.
Swinginking started following Silencer Rattle fix?
Hi, Wondering if anyone knows of a fix to this, I get this crazy rattle at above 4k RPM's on my Nvidia N1 when the silencer is in, I think it is down to how im bolting it, just using a M8 screw + Nut + Washer, am i missing something here?. Im almost tempted to put sound deadening material like silentcoat around the silencer, not sure if this is a good idea due to heat. Thoughts?
Yup, that is him, and he requested £350.00 for that...such a rip-off Also, thread can be closed. Purchased a Headunit
Didnt know this was possible, I am intersted, PM me
Hi, Looking for a aftermarket Headunit, perfer android auto / android OS. Thanks
Perfect! Just what I needed, Thanks for all the help guys Sent from my ONEPLUS A6003 using Tapatalk
Bump Sent from my ONEPLUS A6003 using Tapatalk
Yeah, I think so too. I saw someone on the other forum with a similar set up including the drop, the rears had the slight poke but the fronts didn't, so I guess tiny spacer for the fronts. I'll see when they get here and post pics for opinions Sent from my ONEPLUS A6003 using Tapatalk
Thanks for the help decided not to go for them Bought some wedssport tc105n 17 x 8 x 42 in bronze instead! Sent from my ONEPLUS A6003 using Tapatalk
Thanks [emoji106] have you had any issues with this like rubbing? Sent from my ONEPLUS A6003 using Tapatalk
Hi Guys, Total newb here, Wondering if there might be any problems running this fitment on a 2 inch drop set up. Can't see anyone else running something similar on the states forum too I want about a cm of poke from flush. Thanks
