Eezie86 last won the day on August 3 2019
Eezie86 had the most liked content!
About Eezie86
Dudley
These still available? Sent from my 2107113SG using Tapatalk
Eezie86 started following Newbie from West mids :D, Valenti Taillights red, Please Help - Brakes and and 5 others
Changed mine to ebc green stuff with brembo discs which did squeek untill they got worn in. Have a look to see if there's any debris stuck in the caliper anywhere aswel. Sent from my J8210 using Tapatalk
Nice Sent from my J8210 using Tapatalk
I didn't realise they went on the primo, though the trd was special lol Sent from my J8210 using Tapatalk
The 277mm discs don't fit on mine, had to be the 295mm Sent from my J8210 using Tapatalk
I think my brake change cost around around the £600 mark and that was for discs and pads. Made the vital mistake of not realising the trd disc are slightly bigger [emoji23] Sent from my J8210 using Tapatalk
Have a look about, you'll find some good deals Sent from my J8210 using Tapatalk
A good set for general daily driving should be fine for a good time. I had Toyo proxes for 2 years which needed replacing due to my camber wearing the inner edges (I have aftermarket suspension). Sent from my J8210 using Tapatalk
Tyres are can start from £100 a corner if you want a good set Yearly service can vary depending if you do it your self or go to a garage. Oil and filter service done yourself can cost about £80 The engines are mechanical sound it cared for, mine has 75k and the only mechanical issue I've had is a pulley bearing failed which was £70 for the part from Toyota. Brakes vary depend on which pad you chose either It being cheap or high end. Sent from my J8210 using Tapatalk
Sounds good, try and come along Sent from my J8210 using Tapatalk
Got a rocket bunny ducktail if you're interested Sent from my G8141 using Tapatalk
Hi everyone, Selling my replica Rocket bunny ducktail. Looking to buy something new so looking for additional funds. Smudge Mark in lower left of leg. £180 o.n.o Pick up from Stourbridge. Sent from my G8141 using Tapatalk
[emoji112] [emoji112] Sent from my G8141 using Tapatalk
Sounds like a good idea, I'll be up for that Sent from my G8141 using Tapatalk
Japanese Performance Show - Meaty86 (19th August)
Eezie86 replied to willfmair's topic in Social Meets
I think it starts a 9 am mate Sent from my G8141 using Tapatalk
