sentinal187
About sentinal187
sentinal187 started following CGR EL Exhaust Manifold , Rear View Mirror and OEM PreFacelift Alloys - New/Mint condition - £150
Sold Sent from my SM-G950F using Tapatalk
Stock 2018 wheels and suspension
sentinal187 replied to sentinal187's topic in For Sale GT86 / BRZ Parts
Looks like shipping is 40-50 assuming you're in the uk Sent from my SM-G950F using Tapatalk -
I would, would need to find a good way of packing them Sent from my SM-G950F using Tapatalk -
Wheels still here, they are located in Norwich but I will be travelling to grimsby and sudbury over the next month Sent from my SM-G950F using Tapatalk -
Suspension sold, wheels still here Sent from my SM-G950F using Tapatalk -
sentinal187 replied to Leeky's topic in For Sale GT86 / BRZ Parts
If he doesn't I have some for sale bud Sent from my SM-G950F using Tapatalk -
As per title, made 300 bhp on my Supercharged gt86. The manifold is a work of art! Includes overpipe More details can be found here https://www.cgrautomotive.co.uk/product-page/toyota-gt86-subaru-brz-exhaust-manifold-supercharged Because it's been in the car it's not as shiny as in some of the pics but can be polished back to this state. Otherwise in excellent condition 500 plus post or you can collect from Norwich Sent from my SM-G950F using Tapatalk
Dont believe there was any tracking changes but hard to find proper detail. https://r.tapatalk.com/shareLink/topic?url=http%3A%2F%2Fwww%2Eft86club%2Ecom%2Fforums%2Fshowthread%2Ephp%3Ft%3D114625&share_tid=114625&share_fid=48281&share_type=t&link_source=app Does sound like the ride is more refined on the later cars. Sent from my SM-G950F using Tapatalk -
sentinal187 started following For Sale GT86 / BRZ Parts
sentinal187 started following Stock 2018 wheels and suspension
Stock wheels from a 2018 car, great condition with loads of tread. 200 Suspension off 2018 car, revised spring rates in excellent condition. 150 Sent from my SM-G950F using Tapatalk
sentinal187 reacted to a post in a topic: Brake pedal firm at first but goes soft if holding pressure
sentinal187 replied to Adi's topic in Mechanical
So I have speed bleeders on my brembos, every other trackday I bleed some off to keep it fresh as the fluid just sits in a hot cailper. Takes 30 mins tops. I'd be tempted to try that and see if that helps, also you're banging in the trackdays (bravo!). The fact you're getting pedal sag makes me think the fluid is giving up. Once you boil fluid it's more prone to sagging later. I just use cheap dot 5.1 as by definition it has a better boiling point that dot 4 (not better than the racing stuff mind) with the view of refreshing it by bleeding as I say. As you may already know, brake fluid is hydrosopic so it ages over time, the harder you are on it the shorter it lasts. Another thing to try is adding some ducting to your brakes if you have not got this already and for the cost of it I would get rid of those rubber lines! Sent from my SM-G950F using Tapatalk -
How many track days are you doing a year? Did you flush the fluid? Are you using millers dot 4 300? Without being rude, how are you braking? It's better to brake harder for a shorter period of time versus less pressure for a longer amount of time. I have seen many people on track days riding the brakes then wondering why they get fade. Sent from my SM-G950F using Tapatalk -
Bad mc would give you an issue all the time in my view, not just when your on track. Do you drive the car solely on track or do you use it as a road car as well? How long are you running out on track? 20, 30 mins etc? Sent from my SM-G950F using Tapatalk -
Point is braking technique affects the amount of heat generated, point is maintenance affects braking performance as well. If you go for a full blown race pad you compromise on the road - which is fine if the OP wants that. There are many people of the forum using fast road style pads with no issue on track and in the sprint series. Sent from my SM-G950F using Tapatalk -
Depends how you brake and how long for. At snetertton, 130 mph down to 40-50 never any issues with fade. I had ds2500s on the rx7 and no issues on that either. I am on road tyres and I run 20min sessions on track. Fundamentally these cars are not heavy so dont need much to slow them down. If you're on semis the pads will be working harder however Sent from my SM-G950F using Tapatalk -
Other question is, the pads you mention on both front and rear? Sent from my SM-G950F using Tapatalk
