Chung86
Authorised Seller-
About Chung86
never try it, will double check tomorrow for you
that’s good. mine is facelifts so key is different.
All back in stock now
No at the moment sorry . back order , when back in stock i will post up
Power Block ( inlet manifold spacers ) supply and fitted services
Chung86 posted a topic in For Sale GT86 / BRZ Parts
Hi All, i can supply and fitted Power Blocks ( inlet manifold spacers) power block import in Japan , in stock in UK. drive in / drive out services, locations is Birmingham fill all year GT86 tested on my own car, feel difference straight away after, better throttle response. price is £300 any question please ask or pm me thank you -
yes . in stock
There was 3 wire need to do , all behind door card. 1. Constant power 2. door lock signal 3. door un-lock signal thank you
i can do it to most of the toyota factory HU
Instruction will comes in the box with the item .
Instructions comes with the item. 3 wires to do this is the video IMG_0267.MOV IMG_0267.MOV
Not now, but i try to make one tomorrow
Yes you can . yes if manually press to fold in , it will not unfold until you press the button again .
Ok , i will pm you now .
Yes , will sent you a few photo to shows which wire to do.
Chung86 started following GT86 auto folding mirror kit
auto folding mirror kit les your mirror auto folding when lock vehicle, and un fold mirror when unlock or ignition is switch on. fit inside door card, 3 wires to splice in. price is £60 delivered
