About Kal
Warrington
3744 profile views
Hi I donβt think there will be any damage done, I had this exact problem also.I must have done over a thousand miles , before I changed the diff.oil for motul gear300 75w-90. This gear oil completely eliminated the low speed judder whilst turning at low speed. I can only guess that certain gear oils from toyota cause the diff to lock , at low speed turning and it gets worse once warmed up. But donβt worry Change the diff oil and your good to go.
Iβm from Warrington too , will keep a eye out for you, ππ½
Iv had the same symptoms as you described, also after diff oil change from Toyota! I cured the problem completely with diff oil change which was recommended by tuning developments in Warrington. I used motul gear 300 75w-90, I suspect toyota gear oil is the problem.
Hi I also have the TRD version, although it looks good with the kit and wheels, the urge to modify will get you eventually π
Very nice, not many officials TRD versions in redππ
Does it come with the brembo brake package as in the first pic??
Open Day Spring 2017 @ Tuning Developments 16/04
Kal replied to Mike@TD.co.uk's topic in Tuning Developments
Count me in too, I finish paying for my 86 in Dec. Got money burning me for a turbo kit.π- 126 replies
- tuning developments
- open day
(and 4 more)
Toyota UK - Tada San Meet 24/06/16
Kal replied to will300's topic in Meets/Show & Shine - Pictures & Videos
Thanks to everyone, I had a fab timeππ» -
Open Day Spring 2016 @ Tuning Developments 27/03
Count me in please, I missed the last one,.- 235 replies
- open day
(and 3 more)
Thanks Lauren , I think I will end up fabricating one up. Toyota no longer list it as available . Do you still have your trueno , I had a good look at it,at the gt86 unavailing at rrg salford. Is still just as nice?
Hi need a battery clamp for Corolla gt(ae86), iv misplaced mine, during a garage clean out! If anybody can help. Thanks
Hi dan, did you use the the trd tail pipe after the turbo conversion? Or is that a restriction for 300bhpish
