About Adam43
New Orleans
I like what it came with. Narrow and not grippy. Not for my race car, but perfect for the road as they are good in all conditions and, here is the important bit, fun. #43
Keethos reacted to a post in a topic: Changing discs and pads
I might check that out especially as the SRF is pretty expensive stuff. And the race car is a whatsit to bleed up! So, 2 1/2 tanks of fuel and a set of yellows later a good time was had by all! :-) The yellows were fine as far as braking performance goes. Felt good, on it straight away, didn't fade over decent stints. However they only just lasted the day, although if I hadn't bothered with the wrap around anti squeal things I'd had almost another couple of mm and another session. Still back to the hardly worn originals with over 30k miles left on them #43
My comment was around some special coating that was on them to make work on the first press to partially combat what you describe. Something they don't have on the blue or orange stuff which I'm normally used to. I was curious how good that was. I did my normal bedding in anyway, which is why I can't be sure how they developed because as you say I eased them in at first. My preferred brake fluid is Castrol SRF, or whatever they call it now. Although the GT86 has standard in it, so I shall limit the stint lengths. #43
I'm impressed. I guess it is quite light compared to most modern road cars. I kept the original pads. I don't think I'll put them back in for road, but keep them for emergency. #43
Thanks for this thread. It made the job very quick as I had the correct sized spanner and sockets ready. Thanks. By calliper rewind tool, I assume you mean piece of wood and screwdriver? ;-) It is a very easy job. I've put yellow stuff on, so we shall see. I shall let you know how I got on. I went EBC because I could get them quick for a track day. Although the last set of EBC I had were blue (different car) and they were gone after two stints at Oulton. I think they must have been faulty as all the material had gone and a piston punched a hole in the metal backing! :eek: They feel good so far. A short test drive showed the 'brake in' coating they have meant they worked from the start. Although I thought they got worse after the initial few presses and then got better again. I might have imagined this though. The car has done 8,000 miles and the original pads were hardly worn, which bodes well. Is that normal, does anyone else experience low pad wear? Pro rate these look good for 40,000miles. It's not a motorway car. #43
Adam43 started following Door Card Removal
faith reacted to a post in a topic: Another newbie
Ah, makes more sense :-) Oulton, a top circuit. Last October I had a brake pad fail. Piston punched a hole in pad! Luckily it happened at a quick corner that didn't need much braking! Sent from my iPhone using Tapatalk
Toyota interest at the Goodwood Festival of Speed
Adam43 replied to Subota Boy's topic in Meets/Show & Shine - Pictures & Videos
A little late to the party, but here are some photos I took at this year's FoS. A great Le Mans car. I saw this coming second. I saw this come close to winning Le Mans The Dakar car The 'special' going up the hill 'twas a good event #43 -
What's the show like this year? Much to see. Is it busy? #43
Tempting. I'm stuck in the garage trying to fix another (track) car at the moment. That's the priority at the moment. It'll have to wait till that is ready for the year. When is it? Cheers. A43. #43
Good that Mallory is back up and running. Is there a full compliment of track days there this year? The race calendar looks fairly full - I'm there with the Classic Sportscar Club in August. Packers look good, if Aaron Rodgers is fit.
Chose a circuit :-) thanks for gate kind welcome. #43
Ah, New Orleans is a lie! Just a hang over from being a Saints fan. I'm nicely in the middle of many tracks; Silverstone, Mallory, Donington, Bedford Autodrome and others are all close. :-) #43
I got my car just before Christmas. Went for it because I liked the small tyres, simplicity and great turn in. It's the usual red, with Sat Nav and leather - I wasn't chasing the options, but it was an ex demo so came cheap. Looking forward to taking it on the track. It looks like quite a few people here enjoy that. :-) #43
Cheers. Will do. Yes, that was he one that made it look messy. Sent from my iPad using Tapatalk
I can report the kettle technique worked very well for me.. I only removed the TOYOTA badge. I had a hot air blower on stand by, but didn't need it. Polish was good enough to remove the residue of gunk. Thinking about taking the GT86 badge off too. Not sure. More importantly, hello everyone. Sent from my iPad using Tapatalk
